Activity Forums Avid Media Composer TC Window Burn in Avid Xpress Pro….
  • TC Window Burn in Avid Xpress Pro….
    Posted by Scott Pellet on August 3, 2007 at 1:45 am
    I’m on Avid Xpress Pro 5.6.2. Is it possible to put a 29.97 TC Window Burn on a 23.98 sequence and, if so, what’s the fastest/ easiest way to do so? Thanks.
    -s
    Scott Pellet replied 19 years ago 2 Members · 2 Replies
  • Grinner Hester
    August 6, 2007 at 4:43 pm
    yuo can grab a plugin for this but it has to be rendered so I keep a low rez tb burn in clip online and use a pip effect for this when i have to put one to beta. If it’s a burn in on a dvd or vhs, I just loop through the beta deck with super on. This is by far the quickest easist way.
  • Scott Pellet
    August 7, 2007 at 12:51 am
    you mean a third party plug-in, right? thanks.
