Activity Forums Apple Final Cut Pro Legacy TC filter shows in sub sequences, when turned off
  • TC filter shows in sub sequences, when turned off
    Posted by Chris Pulleyn on April 19, 2012 at 12:48 pm
    Hi Guys
    I supplied a file with a TC for client (seq 2 below) to choose bits and ordering, not rocket science. They chopped it as they wanted it in Windows movie and sent it back.
    heres my sequence sub-levels list for ref:
    seq 1 = raw footage cleaned up and consolidated
    seq 2 = seq 1 + TC filter to give 1 timecode
    seq 3 = seq 2 + wmv to edit identically (this seq is now defunkt)
    seq 3A = a direct duplicate of seq 3, (put aside for reference only) adding logos music etc.
    now I have finished, I go back to Seq 2 and turn off the TC filter. No longer visible in Seq 2.
    But, 1 level down in Seq 3 only 1 piece of footage’s TC disappears and the rest stay visible.
    I have dumped all render files, deleted the filter in Seq 2 and restarted, dumped render files, rebooted, searched all discs, ejected all necessary discs …and sworn quite a bit.
    nothing seems to make the TC go away.
    I’m currently considering bringing in a psd that covers everything, rendering, removing it and rendering again, just to try and unblock it.
    Any ideas welcome!
    Best
    Chris using fully-licensed FCP 7.0.2
    Chris Pulleyn replied 14 years, 5 months ago 2 Members · 3 Replies
  • Michael Gissing
    April 20, 2012 at 12:21 am
    In sequence 3 have you changed clip opacity to see the wmv layer with the burn in? If so then try deleting the wmv’s and select all clips and delete attributes>opacity.
  • Chris Pulleyn
    April 20, 2012 at 7:28 am
    hi Michael
    No I didn’t change opacity as I did it roughly using the 2 voices simultaneously.
    I did the tc months ago, so can’t exactly remember how I did it but..
    I see that in seq 3 I copy/pasted the selection and the version I copied the tc has gone but the version I pasted, it stays.
    think it could be the act of pasting it that has bugged the following seq. possible ?
    What I ha
  • Chris Pulleyn
    April 20, 2012 at 12:39 pm
    OK it is resolved, but i think it’s an FCP glitch.
    In seq 3a, EACH cut of seq2 that i made seems to have created its OWN “Ghost” seq2+TC. So i have gone through 100 cuts in seq3a, double clicked and turned off the TC!
    I now have 100x seq2 timelines open where there should be only 1.
    When i say “Ghost” Seq, i mean it doesn’t show up anywhere and seems to only exist in FCPs inner self…
    In conclusion, it seems that when I created the duplicate seq for cutting i presumed FCP would be able to follow the logic and cascade the changes in one go. It can’t… or i have a bug.
    Would be interesting to hear if anyone else has had similar problems?
    Chris
