Activity › Forums › Apple Final Cut Pro › TC Burn In App
TC Burn In App
Posted by Eric Santiago on July 12, 2016 at 6:24 pmIve been testing QT Change and cant seem to get the TC Burn In to work.
Is there another app that can do batch TC Burn In on image (DSLR footy)?
I dont care if the TC is correct just something that lets you at least see TC on screen.
John Fishbackreplied 10 years, 2 months ago 5 Members · 10 Replies
Michael Hancock
July 12, 2016 at 6:49 pmAdobe Media Encoder will do it. It’s under the Effects tab.
Here’s a preset to generate a 360p .h264 file, matching your source frame rate, with timecode burn (for Media Encoder CC 2015 v9.2.0.26).
https://www.dropbox.com/s/1bfpeuu58tjzml8/Timecode%20Preview%20360p.epr?dl=0
Michael Hancock
Editor -
Michael Hancock
July 12, 2016 at 7:49 pm -
Michael Hancock
July 12, 2016 at 8:11 pmYou’re welcome, and hope it helps. That’s the preset I use when we send interviews out for transcription. The files are super small with big timecode.
Another great little feature of Media Encoder is the ability to transcode footage with a custom LUT applied. It’s also under the Effects tab. So if you have Log footage and need to send out low res previews for client/producer review, you can apply a LUT to the footage sand have it stamp timecode all at once, so you aren’t sending out super flat fooage. And it’s super fast.
Michael Hancock
Editor -
Eric Santiago
July 12, 2016 at 8:24 pmThanks for the tips, this will help.
I havent had to do this in ages.
Im used to RED footage exports for dailies using RCX.
I didnt realise AME had this option.
Jeff Kirkland
July 12, 2016 at 11:02 pmResolve would have been another option.
(For some reason I can\’t edit my own posts so apologies in advance for the stupid mistakes and bad English that I can\’t go back and fix)
Jeff Kirkland | Video Producer & Cinematographer
Melbourne, Australia | Twitter: @jeffkirkland -
John Fishback
July 20, 2016 at 8:34 pmSource Timecode is a free FCPX plugin from CoreMelt that now works.
