Tascam DR-60 One Input sounds different
Ari Mannis replied 12 years, 3 months ago 5 Members · 21 Replies
Ari Mannis
May 20, 2014 at 2:38 amIl write down all the settings I have it on wed… because I haven’t changed anything so I’m sure it Wi happen again and I need to fix it so I don’t get fired.
Al Bergstein
May 20, 2014 at 5:32 amAri, you didn’t mention if you checked out my suggestion. If you were recording one track at 10db below the other, it would sound “tinny’. Did you check to make sure that wasn’t the issue?
Al
Ari Mannis
May 20, 2014 at 5:39 amI only recorded one track so I think it only recorded at one volume.
Brian Reynolds
May 20, 2014 at 7:14 amA suggestion for the future, keep the mics on separate tracks for as long as you can, by crash mixing the mics on site very much limits what you can do with the recorded material.
Ari Mannis
May 20, 2014 at 8:36 amHow do I keep mics on serperate tracks in the dr-60?
Also how would i fix the issue if it is a “phase” problem.
Brian Reynolds
May 20, 2014 at 8:46 amSimple…. On the DR60 record as a stereo file with mic 1 plugged into ch1 and mic 2 plugged into ch2, this then gives a stereo file that is then mixed in post production in your computer.
Bob Kessler
May 20, 2014 at 2:53 pmAri – Is your “one track” a stereo track or a single mono track?
Peace,
Bob
____________________________________________________________________
Filmmaking is the art of the invisible;
If anyone notices your work you haven’t done your job right.
