Activity › Forums › Adobe Premiere Pro › target sequence tracks in CS4
  • target sequence tracks in CS4
    Posted by Mike Cohen on March 9, 2009 at 7:09 pm
    On CS3, I had a keystroke to target the higher or lower video track, and higher or lower audio track.
    This was useful when applying the default transition at the cursor position, and of course for adding media to a particular track.
    In CS4, you lose keystroke targeting of tracks, and it seems you need to click the tracks you want to be active.
    Also, if more than one track is active, and you have a cut on multiple tracks at the same cusor position, and you apply the default transition, you get the transition applied to all active tracks.
    This adds a lot more clicking to do the same thing.
    What am I missing?
    Mike Cohen
    Mike Cohen replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
