Activity Forums Maxon Cinema 4D Target Camera targeting moving object
  • Target Camera targeting moving object
    Posted by Alex Reardon on January 25, 2011 at 7:55 pm
    Hello Again C4D Gurus,
    I am trying to make a target camera that is aligned to a spline look at (track) an object that is also aligned to another spline. If I select the object as the target, the camera looks at the object in the 3D space it is in before it has been attached to the spline and not where that object is in its path along the spline.
    Can you help please.
    Thank you – as always.
    Adam Trachtenberg replied 15 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 25, 2011 at 9:45 pm
    Works fine here. Are you sure you dragged the object into the camera’s target tag?
