Activity Forums Maxon Cinema 4D Target and Bake rookie question
  • Target and Bake rookie question
    Posted by Jose Villanueva on July 29, 2010 at 8:49 pm
    thanks in advance for any help! got a golf ball (in a cloner) rolling down a ramp (tilted plane) using mograph rigid body tags. so, a couple of questions. how can i use that ball as a camera target since the target tag doesn’t know the ball is rolling? do i just need to fake it with a null? so i like how everything is working, can i bake(?) that animation so it doesn’t have to recalculate? or should i be using the solver and the rigid body dynamic tag under dynamic tags as opposed to mograph? sorry, i’m such a rook…i do appreciate everyone’s time !
    Jose Villanueva replied 16 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    July 29, 2010 at 9:18 pm
    You’ll need a little Xpresso to track the sphere:
    * create a null and drag it into Xpresso editor;
    * create a Coords>Global Position in port for the null;
    * drag cloner into Xpresso editor;
    * create an Object out port for the cloner node;
    * create a mograph>data node and connect the cloner’s object port to the data node’s object port;
    * connect the data node’s position port to the null’s global position port;
    * drag the null into the camera target’s reference box.
    You can cache mograph dynamics with the mograph cache tag. The regular dynamics objects/tags have no connection to modynamics.
  • Jose Villanueva
    July 29, 2010 at 10:30 pm
    that worked perfectly, thanks so much adam…i appreciate it!
