Activity Forums Adobe After Effects Targa Sequence Render Error
  • Targa Sequence Render Error
    Posted by Mike Moss on January 9, 2011 at 7:24 pm
    Ok,
    I have a Targa sequence that was created in AE CS3 (about 3000 frames long),
    I had to bring that back into AE and re-render that sequence out to a Quicktime movie.
    It goes through about 10 or 15 frames then stops and gives me the error “Could not parse the file”
    I checked for reasons and saw Dave’s thread to make sure it wasnt in CMYK. It is not (RGB). I also saw people having this same error when only tyring to IMPORT INTO AE, not rendering out.
    It imports fine, i can scrub through my timeline and it looks fine.
    But rendering, is another story…
    Any ideas?
    —nevermind, i figured it out! 🙂
    Mike Moss replied 15 years, 8 months ago 2 Members · 6 Replies
  • Graham Macfarlane
    January 10, 2011 at 1:40 pm
    I’m curious, what was the cause of the error?
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
  • Mike Moss
    January 10, 2011 at 4:24 pm
    IM not 100% sure what originally caused the error when i first tried rendering it out. I would get some frames completed then get the error. So i i deleted the 10 frames, and try again…same error
    Next i tried, leaving the 10 completed frames there and rendering again, this time checking the “skip existing files” box. and it finally worked.
    BUT i couldnt take THAT sequence and render it out. i was going nuts. Finally i looked at all my targa files that rendered out and frame 10 said “0(zero)K” so deleted that single frame and rendered again with skip existing files an it finally worked.
    So, like i said im not sure why it originally would crash, but either way i got the job done. Its going to be very annoying it i have to do this every time.
  • Graham Macfarlane
    January 10, 2011 at 4:42 pm
    were you rendering over a network?
    Graham Macfarlane
    London UK
  • Mike Moss
    January 10, 2011 at 4:49 pm
    Nope, just a single machine.
  • Graham Macfarlane
    January 10, 2011 at 5:03 pm
    If you are using a PC then it’s worth noting that occasionally you can get “delayed write fail” pop up on the bottom right of the desktop (little yellow exclamation mark symbol).
    I find this happens occasionally over network storage and very very occasionally on local storage if the OS has some problems.
    I’ve never managed to locate a solid cause for such glitches though.
    It is rather unlikely but possible that this might have been the reason for a random TGA file not to save correctly.
    Graham Macfarlane
    London UK
  • Mike Moss
    January 10, 2011 at 5:05 pm
    Thanks, ill keep that in mind.
    Although im PRETTY sure that i did not get one of those. But then again, i may not have noticed it.
    Ill keep an eye out for it if i run into this problem again.
    thanks. 🙂
