Activity Forums Adobe After Effects Targa File won’t import into After Effects
  • Targa File won’t import into After Effects
    Posted by Tony Venezia on May 6, 2012 at 2:29 am
    I have created several Targa sequences directly in After Effects. When I attempt to import them back into After Effects I get this error message: “after effects error the file format could not parse the file. ( 45::35 )” I have been creating targa image sequences like this for years and haven’t had any trouble. Now all of a sudden this raises its ugly head. I am able to work around the problem by setting up a batch save and convert in Photoshop and converting the files to .PSDs. But it’s a pain. Does anyone have any insights regarding this issue?
    Eric Santiago replied 14 years, 4 months ago 2 Members · 3 Replies
  • Eric Santiago
    May 7, 2012 at 1:07 am
    Just in case check if its CMYK or some other type of format?
    Or check bit level like 8bit 16 etc…
    I havent used TGA in like 10 years.
  • Tony Venezia
    May 7, 2012 at 2:21 am
    Thanks for the response.
    Targas can only be RGB 8 bit. What makes this issue even more perplexing is that I can import targas that were created in After Effects last month. All of the render output settings between then and now are identical. For now I am rendering my sequences to PSDs so I can continue working. But I am on a quest to discover what this problem is.
  • Eric Santiago
    May 7, 2012 at 12:41 pm
    Well that explains why I stopped using it 🙂
    Did you install anything new on that system?
    Do you get the same results on other systems with that file or different file?
