Activity Forums Avid Media Composer Tape won’t capture due to time code breaks – wild or batch
  • Tape won’t capture due to time code breaks – wild or batch
    Posted by Rosie Walunas on November 4, 2012 at 11:24 pm
    I’m trying to capture a mini-DV tape 4×3 @ 29.97.
    When I log the clip it ends up stopping at a seemingly random point because of “time code discontinuity” or it “can’t find the pre-roll.”
    When I try to capture it wild, it says I’ve inserted a dropframe tape and that I should insert a nondropframe tape. When I change the dropframe setting to nondropframe, it says that a dropframe tape should be inserted.
    I also tried unchecking the boxes so that the tape will “Stop capture if a bad frame is detected.”
    What else can I do? The tape doesn’t seem to be bad.
    Thanks.
    Rosie Walunas replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
