  • Walter Biscardi
    June 12, 2009 at 5:47 pm
    [kathleen siegel] “Is there an easy way to remove tape hiss from a clip?”
    Turn the volume down? Sorry, couldn’t resist.
    Try the equalizers to dial out the hiss in the Audio Filters > Final Cut Pro. If you open the FCP Manual using the Help Menu, you can search for Audio Hiss and it brings up some information on the filters on Page 939
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • John Fishback
    June 12, 2009 at 7:23 pm
    You can also use Soundtrack Pro’s noise reduction which is a little more involved. STP “learns” the noise, then acts to reduce it, leaving the rest of the audio relatively untouched. Here’s a Larry Jordan tutorial on how to do it. https://www.larryjordan.biz/articles/lj_reduce_noise_STP2.html
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
