Activity Forums Apple Final Cut Pro Legacy Taking the plunge… FCP studio, Tiger and a homemade RAID… Any advices
  • Taking the plunge… FCP studio, Tiger and a homemade RAID… Any advices
    Posted by Gunleik Groven on September 15, 2005 at 5:18 pm
    I’ve been perfectly happy with Panther and 4.5, but as I now have the option to upgrade… well I will. -;)
    Some questions
    Is it a good idea to keep a volume with Panther and 4.5 for older projects?
    Should I go with QT on both setups?
    Any experiences with the High Point Rocket RAID 2220
    I’ll put 6 400 gb SATA disks in a PC box (for power, fans and brackets) – happily saving some cash which gives me the opportutity to have a RAID.
    My old ATA disks goes into an old G3 and another old PC for backup purposes.
    I currently have 6 Gb RAM. Will that do for Motion on a first gen dual 2 Ghz? G5?
    And what should I do next?
    Decklink?
    Gunleik
    Michael Ruiz replied 20 years, 11 months ago 2 Members · 1 Reply
  • Michael Ruiz
    September 16, 2005 at 8:04 pm
    Im using a 1.4TB sata raid system from macgurus.com
    Im using the Sonnet Tempo-8x external 8 port esata card.
    I just finished an 1hr long segment for the Fine Living Network
    and it worked fine.
    I also, have a SCSI raid system from rourke data.
    I found the SCSI raid to be more responsive. But 3 times the cost.
    I had a couple of hiccups out-putting from the
    Sata drives. It was droping frames at first. I
    powered down and I out-put 3 43min versions
    at 10 bit no problem.
    Beaware, there’s allways something out-putting.
    Good Luck
