Activity Forums Apple Final Cut Pro Legacy taking away a forehead glare
  • taking away a forehead glare
    Posted by Adam Lipp on June 22, 2009 at 11:16 pm
    Hello,
    We shot an interview outside and the camera was hand held. The subject is wearing a headband pulling her hair back and the sun glare on her forehead is really hot. It’s so bad that it makes her look bald. I’ve tried to matte and use other different filters to try to cover up the glare, but since there is so much movement with the camera and the subject moving when she talks it’s hard to use it without it looking too noticeable. My question is there a quick fix, that will allow me to use the interview and make her look like she isn’t balding, because I’m sure she wouldn’t enjoy it. Thank you.
    Adam
    Jason Diebler replied 17 years, 3 months ago 6 Members · 5 Replies
  • Steve Eisen
    June 22, 2009 at 11:27 pm
    Definitely there is no quick fix. Without knowing what format (DV, HDV, etc.) you shot, it may be hard to get good results. From the sounds of it, your video level is way off the chart and you may not have enough dynamic latitude to pull it back.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Mark Raudonis
    June 22, 2009 at 11:42 pm
    Adam,
    If the “blowout” is as bad as you describe, there is NO quick fix. It would probably be faster to
    just reshoot! You could spend hours trying to fix this and still never get as good results as a
    reshoot.
    Good luck.
    Mark
  • Richard Sanchez
    There really isn’t a quick fix. There is a plugin called Captain’s Blowout Fixer (https://pistolerapost.com/pluginz/) that might help. It’s not terribly tricky to use, but will take a little getting used to.
    Richard Sanchez
    North Hollywood, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Nick Meyers
    June 23, 2009 at 2:21 am
    the problem is there is so little information in the blown out area.
    captains blowout filter tries to get around this by accessing the colour channel with the most detail, and using that alone to fill in the area,
    and then, i think, colouring it appropriately
    but on the whole, any solution would involve “colouring-in” the blank, featureless area, with a skin tone.
    i think your talent might still look bald!
    nick
  • Jason Diebler
    June 24, 2009 at 5:31 pm
    The fix might be to use her sound bites and cover the footage w/ b-roll and gfx.
    “The deepest blues are black” – Foo Fighters
    (this doesn’t help me when I’m chroma keying!)
