Activity › Forums › Apple Final Cut Pro Legacy › Taking audio from 2 seperate angles in a multiclip
  • Taking audio from 2 seperate angles in a multiclip
    Posted by Tim Sandik on May 2, 2008 at 3:16 pm
    Is it possible to take audio from 2 seperate angles simultaneously while editing a multiclip?
    If so, how? If not, is there an easy workaround?
    Tim
    Brian Findlay replied 18 years, 5 months ago 2 Members · 1 Reply
  • Brian Findlay
    May 2, 2008 at 4:56 pm
    I’ve done a ton of multiclips, and found a few tricks with audio..*MAYBE* this will help. I had a couple of cameras and a 24 bit recorder that I synchronized the output in a multiclip (musical content recorded of the original source being filmed – dual systems recording). It will let you synchronize and individual sound track just like video. So, my *workaround* would be to pull off both tracks of the audio, go to your favorite sound program and mix them as you would, then bring it back as a separate audio track and select it as the audio source.
    There may be an easier way to do this, but I know this will work.
    Does this makes sense? I hope it helps..
    Brian
