Activity › Forums › Adobe Premiere Pro › Taking a boom out of the shot.
  • Taking a boom out of the shot.
    Posted by Adam Carr on April 29, 2015 at 8:56 am
    I’ve discovered the boom and mic in a shot that I want to make disappear. Is there a way to paste the part of the wall from a previous clip and use it to cover up the boom when it appears in the sequence or any other suggestions?
    Craig Howard replied 11 years, 5 months ago 4 Members · 3 Replies
  • Christian Vilderman
    April 29, 2015 at 10:19 am
    I can fix it. PM ME
  • Declan Smith
    April 29, 2015 at 10:22 am
    It depends on the clip as to what method you would need to employ. Such as whether there is camera movement, does the light change etc etc. I would normally tackle this in something like After Effects, BUT, if you have a suitable ‘patch’ clip and the lighting is the same and there is no movement, then I would suggest using the TextTool to create a feathered mask over the ‘patch’ clip to select exactly what you need and put this on a higher clip in the timeline than the original.
    Declan Smith
    https://www.madpanic.tv
    After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
    “it’s either binary or it’s not”
  • Craig Howard
    April 30, 2015 at 2:07 am
    If you need to comp a patch in ..use a Mask from Opacity.
    If in AEFX ..maybe rotoscope it out and fill the BG with a patch.
    Always hard to advise without seeing the issue. ( image)
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Adobe CS6 Premiere Pro Production Premium Suite
    Windows 7-64 bit:Assus P6T Deluxe Mob, 24 GB BM SDI Decklink, . HD Workflows
