Activity Forums VEGAS Pro System requirements – Vegas 6
  • System requirements – Vegas 6
    Posted by William Wallick on December 28, 2005 at 12:27 am
    Are the system requirements in the manual (2.8, 512MB) realistic, or more like minimums? I have a 3.0 P4 with 2GB RAM, is that sufficient?
    Just another video knucklehead…
    Edward Troxel replied 20 years, 8 months ago 3 Members · 2 Replies
  • Terje A. bergesen
    December 28, 2005 at 12:46 am
    I have a 2GHz PC with 1G of memory, and that is plenty.
    Terje A. Bergesen
  • Edward Troxel
    December 28, 2005 at 2:05 am
    Would you believe I have it running on a Pentium III 300MHz? Naturally I don’t use it for editing but I *DO* test running Excalibur on that machine. I figure if that machine can handle it then YOUR machine should be able to handle it.
    Likewise the XP SP2 requirement for HDV isn’t 100% true either – SP2 just makes it a LOT easier. In SP1, you have to manually add the proper driver. HDV supposedly works in Win2K also… *IF* you can find and install the right drivers.
    Edward Troxel
    JETDV Scripts
