*SYSTEM CRASH* Rendering two lens flares crashes system
Steve Rhoden replied 14 years ago 3 Members · 12 Replies
Evan b. Peters
August 28, 2012 at 12:34 amActually, Steve, the problem wasn’t solved there after all.
I remembered that I changed the property settings from 8bit to 32 in the pixel format. I went and put it back to the original 8bit setting and the problem stopped. If it comes back up again for some strange reason, I’ll let you know.
Does that sound more accurate? The pixel format change being the reason?
Thanks.
BTW: you solved a question I had for YEARS with the quantize option. You learn something new every day! Thank you!
Steve Rhoden
August 28, 2012 at 12:41 amYou forgot to mention that one important factor,
changing the property settings from 8bit to 32 in the pixel
format then would definitely be why its crashing on you.Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956
