Activity Forums Apple Motion SynthEyes Camera Tracker export to Motion running
  • SynthEyes Camera Tracker export to Motion running
    Posted by Ssontech on December 2, 2005 at 8:31 pm
    Just a head’s up that I have a single-path export from the SynthEyes 3-D camera tracker to Motion running now. There’s an example on the our website, see https://www.ssontech.com/download.htm, showing a 3-D point exported. The path continues correctly even after the point goes off screen, since it is calculated from a 3-D solution. For example, after a smoke effect’s emitter goes off-screen, the smoke can still continue to billow out properly, on screen. The export is an XML file, you can drag it from the Motion file browser onto a layer (name).
    Related comments, suggestions, requests, etc welcome – Russ
    Noah Kadner replied 20 years, 10 months ago 2 Members · 1 Reply
  • Noah Kadner
    December 2, 2005 at 11:04 pm
    Great idea! I’m assuming this is Motion 2 only? Couldn’t get it to work in Motion 1.
    Noah
