Activity › Forums › Apple Final Cut Pro Legacy › syncing up audio layers
  • syncing up audio layers
    Posted by Glen Jennings on August 25, 2010 at 3:31 pm
    I’m in a situation where I have pairs of stereo audio layers in a timeline that will need a lot of fade in/outs and it would be efficient if i could link them so as not to have to add all the key frames to both L & R audio pairs (i.e. doing everything twice).
    Is this possible-to link audio tracks so that you only have to add/subtract key frames to them as one layer instead of doing it to both layers. Like linking or syncing them together. It seems like a logical and practical way to do things.
    John Fishback replied 16 years, 1 month ago 2 Members · 1 Reply
  • John Fishback
    August 25, 2010 at 7:12 pm
    You can link tracks using Cmd L. Highlight all the tracks and Cmd L should link them together. You can’t do this when more than one audio track has a video track. Another approach would be to nest the synced tracks. Then by adjusting the nested audio track you would affect all the synced tracks like a master fader.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
