Activity Forums Adobe Premiere Pro Syncing two cameras in Premiere PRO CC
  • Syncing two cameras in Premiere PRO CC
    Posted by Jesse Austin on January 13, 2015 at 7:02 pm
    Hi All, question:
    I have multi camera shoot that I am in the process of editing on CC. “A” camera, C300 and “B” camera, 5D MK III. Both cameras had audio going to them. I have cut the “A” side alone, how do I sync the “B” to the “A?” Thanks in advance for any help.
    Herb Sevush replied 11 years, 8 months ago 3 Members · 3 Replies
  • John Vegt
    January 13, 2015 at 7:47 pm
    Hi Jesse,
    This page from Adobe Help and tutorial might be helpful: https://helpx.adobe.com/premiere-pro/using/create-multi-camera-source-sequence.html#main-pars_header.
    John
  • Jesse Austin
    January 13, 2015 at 8:17 pm
    Thanks John,will look into it.
    Jess
  • Herb Sevush
    January 14, 2015 at 1:37 pm
    [Jesse Austin] ” I have cut the “A” side alone, how do I sync the “B” to the “A?” Thanks in advance for any help.”
    Unfortunately for you, creating a multiclip has to come before you edit your material, not after. Your supposed to sync the A+B camera clips as a whole and then start cutting. Depending on how complex your current edit is you might want to create a multiclip and then re-do your current edits one at a time with the A angle of the multiclip, at which point you will have access to both cameras.
    Herb Sevush
    Zebra Productions
    nothin’ attached to nothin’
    “Deciding the spine is the process of editing” F. Bieberkopf
