Activity › Forums › Apple Final Cut Pro › Syncing 2 Channel/track audio with video in FCPX
  • Syncing 2 Channel/track audio with video in FCPX
    Posted by Daniel Alexander on December 22, 2020 at 5:24 pm
    Hi all!
    New to this forum, excited to chat and learn from the experts!
    My question involves syncing two channel/track audio to video in FCPX.
    I’m capturing dialogue/sound (it’s a cooking show) using two Sennheiser wireless lav mics connected to a Zoom H4N recorder. Each subject/host has her own transmitter and receiver.
    I’m looking for the cleanest/most efficient way to sync this sound to the video while being able to work on each individual mic and mix the two as needed.
    Here’s what I’ve discovered so far:
    1) If I set the Zoom record mode to stereo I get one file and left/right channels. If I sync this audio clip to the video footage manually, I’m able to change it to dual mono channels and edit each mic separately. Noice.
    BUT! When I use Sync clips it no longer allows me to change the mode and work with each mic individually – kind of feels like the FCPX sync clip(s) function flattens everything into a single mono track. Not so noice.
    Alternatively:
    2) If I set the Zoom record mode to Multitrack (MTR) I get two separate mono files, one for each mic.
    BUT! It doesn’t work well to try to sync the footage with both audio tracks. It really only seems to work when I sync the video footage with one of the audio tracks and then attach the 2nd audio track in the timeline.
    Because there are so many variables, I want to make sure I’m not missing something. Is there a way to capture dual track/channel sound and sync it up in one go while maintaining separate channels?
    I tried creating a MCC with the audio/video which synced nicely but didn’t seem to allow me to mix the two mono tracks.
    Thank you for the help, would love to hear your thoughts!
    One thing I will ask is that any advice offered work with the stuff I have right now as I can’t afford to add more gear.
    Daniel
    David Battistella replied 5 years, 9 months ago 3 Members · 2 Replies
  • Tony West
    December 23, 2020 at 1:35 am
    Hi Daniel, with a Multicam/multichannel clip in the timeline, you should be able to select that clip and select “expand audio components” and see all of your audio tracks and adjust them and even add filters to them separately. You should also see them in the inspector. Are you not seeing all the tracks when you expand the components?
  • David Battistella
    December 23, 2020 at 8:10 am
    Consider splitting the audio into dual mono before you import. Although it is an extra step it may save you a lot of time in the long run.
    1- Use a drag and drop utility to split the files. I would use this and it is free.
    LINK HERE
    2- Import the Audio and sync the separate tracks to the video.
    3- edit
    4- pan your tracks in FCP as you wish or keep a centered mono mix for your dialog.
    David
    <font face=”inherit”> </font>
