Synchronized clip doesn’t show audio channel choices.
Curious folks if I am doing something wrong here. I’ve synchronized one video clip with with five audio clips (separate audio tracks from the corder; not one interleaved audio file).
The inspector does not reflect being able to choose which of the five I want to use. I only have two choices in the channel configuration: the audio in the actual video clip and a connected clip which only gives me a mono choice for a1. I expected to see the five mono channels to choose from that I can enable/disable as needed.
Is this only relegated to multicam clips and/or interleaved audio files?
Tangier
