Activity › Forums › Maxon Cinema 4D › Synching with AUDIO help
Posted by Jon Herron on August 24, 2005 at 2:37 amI wanna synch some stuff with audio. Reading the manual I understand that you can play audio tracks in Cinema 4D. Okay sooo I add an sound track…then what the hell do I do. I’ve clicked the play audio button. Where do you chose the track to be played? attributes menu?? dont see it…..help a brotha out
jon
Jon Herron replied 21 years, 1 month ago 2 Members · 6 Replies -
Nolan Scott
August 24, 2005 at 5:24 amOpen the Timeline/File/NewTrack/Sound/select the Track/
in the Sound Properties choose your Soundtrack.
And activate Play Sound and Use Sound.Cheers
Nolan -
Jon Herron
August 24, 2005 at 8:01 pmThank you for the reply Nolan, but where in the world is the sound properties????????????
Here’s what Im doing….
1.Open the Timeline 2.Selecting an object 3.Adding /File/NewTrack/Sound to object 4.Selecting the new Sound Track 5. LOOKING for the Sound Properties in the attributes menu….no where to be found. What am I missing????? I have another book that is saying to do the same thing you suggest, but where are the sound properties?
thanks jon -
Nolan Scott
August 24, 2005 at 9:17 pmWell, You’re doing it absolutely right.
When you highlight or select the Sound-Track in the Timeline
the Sequence- and Sound-Properties should be visible
in the Attributes-Manager.
I just checked it here and it works fine (using a Mac).
I presume there is no difference between Mac and PC.Cheers
Nolan -
Jon Herron
August 24, 2005 at 9:31 pmMan I know its driving me crazy. I keep doing the same thing over and over and no sound properties. Im on a PC…hmmmmmmm
thanks
jon -
Nolan Scott
August 24, 2005 at 11:39 pmWell – just a silly idea .
One has to physically click with the cursor on the track
not only the name “Sound” (sorry about this).Cheers
Nolan -
Jon Herron
August 25, 2005 at 12:43 amBrillant!!! Nolan!! What the heck…I could’ve swore I did that. Wow!! I’m scared about Cinema 4d if I couldn’t even figure that one out. phewww!
Thanks a million man…lol what the hell?
thanks,
jon
