Activity › Forums › Apple Final Cut Pro Legacy › Synching new multiclip angles
  • Synching new multiclip angles
    Posted by Jay Curlee on May 14, 2006 at 4:06 pm
    I have 5 angle multiclip of approximately 4:30 length. I have already edited this 5 angle version. I now want to add a 6th angle. The incoming angle wants to cue to the the end of its length–meaning that I would have to scroll back 4:30 to get it in synch with everything else. Is there any way to enter a timecode number in the overlay window. It would take me at least twenty minutes to scroll the 4:30 and I’d probably get carpel tunnel (sp?)
    jay
    Jay Curlee replied 20 years, 4 months ago 3 Members · 4 Replies
  • Martin Baker
    May 14, 2006 at 6:02 pm
    How did you sync up the original multiclip? When you add an extra angle, FCP uses the same method to determine the sync relationship. So if you used a common in point to sync angles 1-5 then you should mark a corresponding in point on your 6th angle before adding it to the existing multiclip.
    Martin
    Digital Heaven, London UK
    ________________________________________
    AutoMotion – 0-60 graphics in 5.2 seconds – Now Shipping
  • Jay Curlee
    May 14, 2006 at 6:52 pm
    I used an “in” point on the original clips. I set an in point on the new angle but it still uses the end point.
    Jay
  • Dean Sensui
    May 14, 2006 at 7:55 pm
    When creating a multiclip you can tell FCP to sync to the in or out point. You might want to check to see if that setting is correct.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Jay Curlee
    May 15, 2006 at 7:20 pm
    Dave,
    I am trynig to ADD an angle to an existing multiclip which had in point selected as the sync point. I put an in point on the incoming angle. It nonetheless cues to the end of the clip.
    Aloha,
    jay
