Synching Audio On A Project Timeline that Has Already Been Created?
I have a big problem.
I am well into a project in FCPX with video clips that had in camera sound only. I know you can’t auto synch video and audio in the timeline, so I had a solution in mind.
I had intended to replace the clips in the timeline with clips that had synched sound (either compound clips or clips that had been broken apart after being synched compound clips)
I had made the false assumption that the copy and paste attributes function or a similar function would include an option to set the in and out points of Clip A (my synched sound video clip) to match Clip B (the same video clip, but non synched sound).Looking now, I see of course that copy and paste attributes function does NOT have the option I need. Furthermore, and to my amazement, I can’t see or find anything that would allow me to match the in and out points. I can’t believe that something so fundamentally simple would not be a part of an advanced program. I feel like there should be a work around but I don’t know what it is.
1. Does some sort of match function for in and out points for two versions of a clip exist?
2. If not, what is the best solution to my problem?
