Activity › Forums › Apple Final Cut Pro Legacy › Synch Audio before Cutting
  • Synch Audio before Cutting
    Posted by Shaun Saperstein on November 5, 2010 at 1:55 pm
    Hello friends,
    I have a question regarding synching audio before using it. I shot a bunch of interviews with a 7D and recorded the audio on an external Zoom H4N not connected to the camera.
    I was wondering if there was a way to synch the H4N audio with the 7D footage and then store the newly synched footage away in a bin. As of now, I can synch them in a timeline and then link them, then that is all.
    Thanks in advance for the help!
    Sincerely,
    Shaun
    Shaun Saperstein replied 15 years, 11 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    November 5, 2010 at 3:18 pm
    Search FCP’s Manual (help menu) on “Merged Clips” or Merging clips…
    This creates a new clip which appears to be a single audio video file.
    OR you can export those little sequences you’ve used to sync the clips with as self contained movies. This would create new media files that may well be a bit more reliable to use than Merged clips.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Shaun Saperstein
    November 5, 2010 at 3:44 pm
    Much obliged, Jerry!
    A good ol’ search for ‘merge clips in fcp’ and I found exactly what I was looking for. All I have to do is link the clips in the timeline and then drag them into the browser. So simple!
    Cheers!
    -Shaun
