Activity › Forums › Panasonic Cameras › Sync Sound Problem
  • Sync Sound Problem
    Posted by Zach Kuperstein on August 12, 2009 at 4:21 pm
    I’ve shot 720p/24pn footage and recorded audio with an external Tascam recording device at 16bit/48khz. I then try to sync the footage with the audio in FCP using a clapped slate and aside from the clap itself, they are not even close.
    I’ve read forums saying that the sequence settings must match the audio bitrate and they do.
    I should note that the audio is a .wav file if that makes a difference.
    Any thoughts on why my sound won’t sync up? Any suggestions on what I might try to fix it?
    Greg Nosaty replied 17 years, 1 month ago 2 Members · 1 Reply
  • Greg Nosaty
    August 14, 2009 at 3:51 pm
    That is strange. Are they Bwave files (broadcast wav)? You could try converting one clip to an AIFF 16bit/48Khz in iTunes and see if that makes a difference.
    I’ve had some issues with sync when exporting OMF files for my audio post guys so maybe there is some glitch with FCP.
    cheers,
    Greg Nosaty
    Cinemontage Productions Inc
