Sync rectangle with text
https://images.creativecow.net/306096/img-2016-01-12-18-04-35.png
Hi. I need advice. How to sync moving text with rectangle? What I do is create layer with flying text, then add new layer, insert Solid Color, use Pan/Crop, copy and paste even attributes from layer with moving text. But problem is copies not only the movement of text but also its` size. As a result I cant adjust size of black layer
