Activity Forums Adobe After Effects Sync problems with Media100HD ref files
  • Sync problems with Media100HD ref files
    Posted by Tim Silva on April 23, 2005 at 4:49 pm
    I’m having trouble with audio sync working with Media100 HD ref files in AE 6.5. If I play the ref files in Quicktime it plays fine. If I do a RAM preview in AE the audio is out of sync.
    If I render the movie out from AE audio is synced and all is well. Any thoughts on why this happens. I’ve checked all preference settings but nothing is jumping out at me.
    Tim
    Tim Silva replied 21 years, 5 months ago 2 Members · 2 Replies
  • Filip Vandueren
    April 24, 2005 at 6:02 pm
    When you do a RAM preview, there’s a little frame-rate counter in the Info-window, if it turns red and says “NOT realtime”, your audio will be out of sync with what you you’re watching.
    Try previewing in halfres if that’s the case.
  • Tim Silva
    April 25, 2005 at 12:13 pm
    I found that whenever the preview is less than full res the sync problem occurs. A full res preview runs fine. Weird.
    Tim
