Activity › Forums › VEGAS Pro › Sync Problems
  • Sync Problems
    Posted by Brian Scott on September 28, 2006 at 9:38 pm
    I’m having problems with lip sync drifting in the project. It looks fine on the timeline, but by 4 minutes in the audio is off by 5-6 frames. I have tried rendering separate wave files, and those are out of sync as well. My originals are MPG files – could that be the problem.
    Brian Scott
    President
    Image Design Productions, Inc.
    Brian Scott replied 20 years ago 2 Members · 2 Replies
  • Peter Wright
    September 29, 2006 at 4:43 am
    May be to do with MPG2 Brian, but it may only be “apparently” out of synch during preview – have you tried selecting a short loop region then using Ram Render (Shift/B) If this is in synch, you should be ok when you render.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Brian Scott
    September 29, 2006 at 11:57 am
    The out of sync is really there. When I “render (Shift/B)” on the timeline it appears pretty close. But when I render out a file, the sync gets worse and worse as time goes on. Even if I render a separate wav file, the problem is there. Here is the odd thing, if I render a wav file of the source mpg, and try to lock it to the video, the waveforms appear to line up. When I zoom in past a certain point, the waveforms on the mpg audio shift to the right – showing they are really out of sync. And when I play both audios, you can hear the separation very plainly. I havent run into this before, but I haven’t edited with mpgs much either.
    I ended up having to render wavs of all the source files, and trying to match them to the edited material. I thought I could save the time I had already spent, but it took awhile to resync. It may have been just as fast to lock the wav and mpgs first and then re-edit!
    Brian Scott
    President
