Activity › Forums › Apple Final Cut Pro Legacy › Sync Problem
  • Posted by Rap on December 5, 2006 at 10:07 pm
    I don’t know where to best post this, so I am putting it here and under Audio Pros.
    I can understate how appreciated any help would be!!!
    I am working on Protools LE 7.1
    I am working with 2 editors both working NTSC projects on FCP. The 2 have given me Bounces of the 2 separate films they are working on, with the same settings as far as I can tell (29.97 DF, 48kHz, 16 bit), the outcome, however has been different. I bounced them both stereo interleaved at the same data rates they gave me
    Editor 1’s project was in perfect sync
    Editor 2’s was not as pretty!!
    The sequence seems to get progressively out of sync…although it doesn’t feel as bad as the difference between Pal and NTSC (4.97 FPS).
    How else can I end this but HELP! and I really hope its not a matter of redoing the project because the audio was horrible (imagine the sound the neon light being as loud as the signal generated by the person speaking!!!!)
    Rap replied 19 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
