Activity Forums Adobe Premiere Pro Sync Issues
  • Sync Issues
    Posted by Kyle Conner on May 6, 2008 at 8:14 pm
    I imported a one hour 3 minute video. On the tape, the sync is fine, but once it’s digitized, it gets more and more out of sync as the video goes on. I noticed in the properties that the project audio sample is 48000hz with a 32 bit floating point, but the source audio is 32000 hz with a 16 bit. Could that be my problem? If so, how can I change it. If that isn’t the issue, any reason why this could be? The frame rate for both the project and capture is set to 29.97.
    Mike Martinez replied 18 years, 3 months ago 3 Members · 2 Replies
  • Vince Becquiot
    May 7, 2008 at 5:03 pm
    What was it captured from ? Digital, analog ?
    Vince
  • Mike Martinez
    June 4, 2008 at 9:30 am
    I am having this problem too – I was capturing fine for years with Adobe Premiere 6.5… but then suddenly all my A/V captures get progressively more and more out-of-sync as they go on. Once it goes over 10 minutes, it’s noticeably, once it’s at an hour into the captured video, it’s unwatchable!
    I upgraded to Premiere Pro 2.0 and the problem persists! I’ve tried capturing in both non-drop and drop-frame modes… I’ve tried 32000 and 48000 khz audio… and NOTHING works!
    Strangely enough it plays back fine in Windows Media Player in perfect sync.
    …But I can’t DO anything with it! As soon as I take the AVI file into Encore or Premiere, it’s out of sync again!!! It sounds like I’m not the only one… is there a reason for this?
