Sync Issues with FCP and ProTools
Hey there everyone. I’m having a rather strange issue with Final Cut and ProTools. I’m hoping someone has come across this problem before and might have a solution.
We recently posted a feature length film in Final Cut and ProTools. We opted to post in True 24p for the entire project with the intent to output directly to 35mm film at the end of the process. Here was our workflow:
All of the footage was brought into Final Cut as 24p Quicktime movies. Audio was brought in at 48k 24bit. The film was edited and everything was in sync and working perfectly.
We then created a quicktime movie of the entire film at 24p along with audio and send that file over to our ProTools studio. The quicktime movie was opened in ProTools and the audio was imported from the same quicktime file. We placed the audio on a track and everything synched perfectly. The ProTools session was set for 24 FPS Time Code as well. We then performed ADR, Foley, added Music, etc. in our ProTools session and still everything is in sync. No problems so far.
Here’s where we’re running into trouble.
We performed a bounce to disc of the entire session in mono (roughly 90 minutes) and sent the resulting mono AIF file back to our Final Cut station for use as a reference audio track. We imported the resulting mono 48k 24bit AIF into Final Cut and dropped it on the timeline, and now, nothing syncs up correctly. The strange part is, we have the standard 8 second leader with beep at no. 2 at the head of the film, and when we import the reference audio back into final cut, the tone (which is only 6 seconds in) is late. To make matters worse, the audio at the end of the 90 minute film is EARLY. It’s almost as if the entire audio file was time compressed, despite the fact that the audio clip is showing as the proper length on the time line.
All settings matched throughout the entire workflow (48khz 24bit audio) so I thought maybe it was a problem with AIF? I rebounced the entire audio session from ProTools as a Broadcast WAV (BWF) thinking the additional Meta data might give FCP the extra info it needed to sync the audio, but the exact same issue resulted. No sync.
I’ve never had this problem before, but then again, I’ve never worked at true 24fps, or worked on a 90 minute long project. Has anyone encountered this problem before or know of a solution? Any help would be appreciated.
Greg Steiner
Q Station
gsteiner@q-station.com
