Activity Forums Apple Final Cut Pro Legacy sync issues while subtitling
  • sync issues while subtitling
    Posted by Nikolai Metin on April 26, 2011 at 8:41 pm
    Hi!
    I’m subtitling a miniDV shot interview project using FCP’s text tool. Some clips go out of sync when I put subs over them. When I disable subs, those clips go back to being synced. Couldn’t find answers in archives.
    Nikolai Metin replied 15 years, 5 months ago 2 Members · 2 Replies
  • Mark Laslo
    April 27, 2011 at 1:21 pm
    Have you tried rendering those sections? I’ve had issues where things will seem slightly out of sync until a render.
  • Nikolai Metin
    April 27, 2011 at 4:06 pm
    tried that. Rendering gets rid off jumpcuts in between subtitles on the same interview clip, but it remains out of sync. Whereas if I delete/disable subtitles over those clips, video goes back in sync. Mind you, it’s only a problem with about 10 clips. The rest of the 45 min project remains in sync and unaffected with subtitles or without.
    I have an option of importing an older export of the project, put subs over that and reexport it, but I don’t want to do that – the project already has too much DV/archival footage and I want to avoid generation loss.
