Activity › Forums › Adobe After Effects Expressions › Sync Drop down menu with an effect drop down menu
Posted by Maria Pixamins on March 12, 2024 at 7:42 pmI REALLY need to sync an effect drop down menu – Saber presets
to the “expressions controls” drop down menu.
Any ideas?
Maria Pixamins replied 2 years, 6 months ago 2 Members · 4 Replies -
Dan Ebberts
March 12, 2024 at 8:29 pmI don’t think there’s any way to access the names of the effect menu items, either through expressions or scripting, if that’s what you mean.
Maria Pixamins
March 12, 2024 at 9:08 pmThe only way might be to duplicate the effect layer 10 times for example. All ten (layer) versions will include different drop down menu setting. Then I will include those 10 different options in an effect drop down menu via opacity.
P.S
I remember I did manage to use the element 3D effect drop down menu – render quality – in a check box controller so selecting the controller on or off I did managed to switch the effects E3D drop down menu for render quality between High quality and draft.
Dan Ebberts
March 12, 2024 at 10:52 pmYou can put an expression like this on the Preset property to connect it to a dropdown menu, and it will change the preset name as expected, but it doesn’t seem to update the rendered result:
m = effect("Dropdown Menu Control")("Menu").value;
switch(m){
case 1:
r = 3; // Are Reactor
break;
case 2:
r = 4; // Cellular
break;
case 3:
r = 5; // Burning
break;
case 4:
r = 6; // Core
break;
case 5:
r = 7; // Electric
break;
default:
r = 1; // Default
break;
r -
Maria Pixamins
March 13, 2024 at 7:02 amYou are right! Although the values are changing they are not rendered.
That’s really weird! Looks like a dead end to me.
P.S.
It’s my honor charting with you sir, you are an expert!
