Activity Forums Adobe Premiere Pro Sync cuts from edited angle to unedited angle of two camera setup
  • Sync cuts from edited angle to unedited angle of two camera setup
    Posted by Seb Neu on March 27, 2018 at 8:57 am
    Hi!
    Sorry if that sounds complicated.
    I record an interview with two cameras at different angles (including a clapper board for audio sync).
    At the end, I have 2 files: A and B.
    On the road, I’d like to cut A resulting in a Sequence.
    After that, I want to bring in B and ideally sync/create cuts that match A in the Sequence.
    Is that possible at all?
    Thank you so much!
    Sebastian
    Blaise Douros replied 8 years, 5 months ago 2 Members · 1 Reply
  • Blaise Douros
    March 27, 2018 at 4:29 pm
    Sounds like you need to create a Multicam sequence.
