Activity Forums Adobe Premiere Pro Sync Audio with a longer video
  • Sync Audio with a longer video
    Posted by Ehsan Shabani on May 29, 2019 at 2:03 am
    Hi everybody.
    I’m having a question about syncing audio with video, but there’s an important difference here.
    Let’s consider I have a dubbed audio with less duration time (for example: 01:30:20) which is for a censored version of a movie and I wanted to sync it with the original file (for example this one is 01:32:10). Is there any automated process for doing this?
    I tried to find a way but all tutorials refer to syncing those videos and audios which are recorded with multiple resources and couldn’t help me.
    Ehsan Shabani replied 7 years, 3 months ago 2 Members · 4 Replies
  • Ehsan Shabani
    May 29, 2019 at 9:37 am
    Thank you!
    But As I have both them in video clips and not just audio files, What if I use “scene cut detection” capability to detect censored areas in timeline?
    Can this work? Really need to find the easiest way for this 😀
  • Greg Janza
    May 29, 2019 at 4:38 pm
    Put both clips in a timeline and then highlight both, control click and select sync. Premiere should be able to sync the waveforms.
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • Ehsan Shabani
    May 29, 2019 at 8:15 pm
    Thank you veryyy much Mr LaRonde!
  • Ehsan Shabani
    May 29, 2019 at 8:21 pm
    Thank you for response.
    This method doesn’t work for this case.
    Look at this photo:
    https://pasteboard.co/IgZoS5o.jpg
    The censored version of audio is about 43′ and the original is 45′ . and the first censored part is in about 00:34:XX
    Looks like there’s no way to match the waveforms automatically.
    I need to do it by hand…
