Activity Forums Avid Media Composer Sync Audio and video in preview?
  • Sync Audio and video in preview?
    Posted by Brian Jaggers on October 17, 2009 at 12:20 am
    Hi, I am working on a project where I will be editing two MOV files in Avid Media Composer 3.5. They are fine with the exception that the audio is noticble out of sync, about a few seconds off. I would like to just go ahead and sync the master file in the preview window so i can sub-clip the various takes, How would I go about syncing these 2 files before they enter the timeline?
    Job Ter burg replied 16 years, 10 months ago 3 Members · 2 Replies
  • Grinner Hester
    October 17, 2009 at 3:37 pm
    Just put em in syunc and use that timeline as a source.
  • Job Ter burg
    October 17, 2009 at 5:14 pm
    If you sync them up in a Timeline, then you may use Autosync to create a sync clip, so you won’t have to manually drag sequences into the source monitor.
    Or, in a 35mm project, use Perf Slip on any synced clip to slip sync by 1/4 frame increments.
