  • Posted by James Ewart on July 10, 2012 at 5:18 am
    Sorry this must have been posted but I cannot find the thread. How do you pull audio back into sync once you have detached it please…there appear to be no indicators that I can find telling you how many frames out of sync it is. I am having to match frame (sorry reveal in event browser) and then drop the clip back in with audio attached which is a little tedious.
    Many thanks
    T. Payton replied 14 years, 2 months ago 3 Members · 2 Replies
  • Oliver Peters
    July 10, 2012 at 1:54 pm
    Currently there are no out-of-sync indicators and no way to automatically slip or move audio back into sync, once the audio is detached or clip items are broken apart.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • T. Payton
    July 10, 2012 at 3:50 pm
    A bummer there are no out of sync indicators. However, you can get audio back in sync in some cases, sorta.
    Select your clip that has detached audio (not broken apart clip) and hit shift-F. This will reveal the clip in the event browser. Then shift-R to replace it, and it will bring back the audio and video.
    Note that this does not currently work for broken apart clips, just detached audio. If you try to shift-F on broken apart clips you’ll see it does nothing.
    T. Payton
    OneCreative, Albuquerque
