Activity Forums Avid Media Composer Symphony DNxHD to H.264
  • Symphony DNxHD to H.264
    Posted by Terry Leahy on July 6, 2012 at 10:42 pm
    Quick question. I have a Matrox MXO2 mini on the way and just want to make sure I can use it in the following way. Edit in DNxHD and put in a bunch of different codecs. Export to H.264 Really freaking fast. Put video on Youtube, all while monitoring it on an HD monitor plugged into Matrox box. Yes?
    Terry Leahy replied 14 years, 1 month ago 3 Members · 3 Replies
  • Shane Ross
    July 7, 2012 at 3:39 am
    [Terry Leahy] “Edit in DNxHD and put in a bunch of different codecs.”
    Convert all those codecs to DNxHD…yes. You can’t edit all sorts of different codecs native in Avid.
    [Terry Leahy] “Export to H.264 Really freaking fast.”
    If you got the Mini with MAX…yes. If just the regular Mini…no. Need the MAX for this.
    [Terry Leahy] “Put video on Youtube, all while monitoring it on an HD monitor plugged into Matrox box. Yes?”
    Yes.
    Shane
    Little Frog Post
  • Job Ter burg
    July 7, 2012 at 9:58 am
    PC or Mac? I think that the MAX option is more accessible on Mac than on PC.
  • Terry Leahy
    July 7, 2012 at 4:36 pm
    I did get the mini with the Max and I am running on the latest Macbook Pro Retina Display. I will be editing spots using P2 media (AVC intra) mixed with DSLR. I should be able to convert that quickly to DNxHD and do my edit and then export wicked fast to H.264 so I can get to the upload faster. Will the conversion to DNxHD take a looooong time? I’m just trying to get in a position to edit as fast as possible with file based media and (rarely) a direct ingest from my camera.
