Activity Forums Avid Media Composer Symphony 6.0.1 and DeckLink HD Extreme 3D Freeze on playback
  • Symphony 6.0.1 and DeckLink HD Extreme 3D Freeze on playback
    Posted by Yair Oren on March 5, 2012 at 5:03 pm
    I Have the above set up with 8GB Ram,Quad Core 2.83GHz, Nvidia Quadro FX580 and Windows 7 64bit. As I know It’s good enough for Avid Symphony. The Big problem I’m having is that The Symphony Freeze a lot when I’m hitting Play. Then I need to restart the software. It happens a lot and I have no Idea why. I tried to change the card setting,render, even went back to 6.0. Nothing helps. Any Ideas?? help….
    Yair
    Alex Maranda replied 14 years, 5 months ago 4 Members · 15 Replies
  • 15 Replies
  • Glenn Sakatch
    March 5, 2012 at 8:11 pm
    Might help to know what you are trying to play. Captures,ama links, native h264?
    Glenn
  • Yair Oren
    March 5, 2012 at 8:19 pm
    Hi Glenn,
    I’m playing HD material 1080i, XDCAM camera cards were trascoded to XDCAM EX 35Mbits and HDV tapes were transcoded to DNXHD 120. I can say that with same materials and with Avid Symphony 5.5 I had no problems at all.
    Yair
  • Glenn Sakatch
    March 6, 2012 at 2:41 pm
    Might indeed be a symphony problem. I’m running MC6.01 with the blackmagic Extreme 3d and having no such problem. Might a reinstall be in order?
    Glenn
  • Yair Oren
    March 6, 2012 at 3:52 pm
    Hi Glenn,
    Thanks for your replay.
    I just uninstalled and install the DeckLink.
    So far so good…
    I’m new to the Blackmagic Extreme 3d,
    Can you tell me what do you think of it’s performance?
    Yair
  • Alex Maranda
    March 12, 2012 at 1:51 pm
    @Yair: I’ve been having the same issue and traced it to faulty Decklink (Desktop Video) version 9.1 drivers. Installing older 9.0 fixed it. Also, you need to “initialize” the Decklink card using the Capture Tool (select Blackmagic for Source, select V, deselect TC, set a name for the Tape Name, and briefly press Capture (flashing red)).
    Doing this works around whatever the issue is. Hopefully they will fix this in 9.2
  • Yair Oren
    March 12, 2012 at 10:34 pm
    Hi Alex,
    I uninstalled the Desktop Video driver version 9.1 and installed 9.0 as you said but Unfortunately it didn’t help. I’m still getting a software freeze(white screen) when i play the sequence and then I have to restart Symphony manually.
    Sadly the only thing that helped was uninstall the driver and remove the card from my computer, then the problem was solve and there was no freezing of Symphony at all!
    Tommorow I’m taking my computer and the Blackmagic card to my diller and see if the card is defect or Avid is not really supporting Blackmagic Decklink card.
    Yair
  • Alex Maranda
    March 12, 2012 at 10:47 pm
    Do the Capture Tool workaround as I described it and it will work. It is hard to say which one of AVID or BM is at fault – maybe both. I lean on AVID. In Symphony 6.0.0 I had to reinitialize the board with the Capture Tool everytime after switching back and forth from Source/Record to Color Correction. In 6.0.1 one initialization (before the first timeline playback) is enough, so it is a modest improvement.
  • Yair Oren
    March 13, 2012 at 7:45 am
    Hi Alex,
    I’m sorry I just tried again everything you said including initialize the Decklink card using the Capture Tool, and still the Symphony freeze on playback for no reason.
    I’m on my way to my dealer.
    Hope replacing the card will help.
    Thanks again
    Yair.
  • Alex Maranda
    March 13, 2012 at 10:42 am
    I don’t think a replacement will make a difference but do let us know. My Decklink works fine in Premiere and FCP, it’s only in AVID that I need to “initialize” it. It’s most likely a combination of AVID issues and BM driver issues. We’ll see if 9.2 drivers fix any of this.
  • Jacob nephi Griffith
    March 13, 2012 at 11:56 am
    I agree with Alex. I am having the same problem. Decklink 3D works in other applications but it crashes on playback in Symphony 6. I will go home and check Media Composer 6. I suspect it will do the same thing. I will also try the workarounds that you’ve described. Please keep us updated on your progress, Yair and Alex.
