Activity Forums Avid Media Composer Symphony 5.5 and 6.0 project compatibility?
  • Symphony 5.5 and 6.0 project compatibility?
    Posted by Brent Hurlock on May 31, 2012 at 5:28 pm
    Anybody had success or failure when moving a project from 6.0 back to 5.5 symphony? I’m sure it will more up.. Can you move one back and forth?
    Brent
    Job Ter burg replied 14 years, 3 months ago 4 Members · 3 Replies
  • Shane Ross
    May 31, 2012 at 6:56 pm
    As long as you don’t use features that are only in MC6/SYMPH 6…such as ProRes MXF…then you would be fine. Newer features never translate back…but Avid has a long history of good backwards compatiblity with most functions.
    Shane
    Little Frog Post
  • Michael Hancock
    May 31, 2012 at 7:13 pm
    Pan and Zoom changed between 5.x and 6. It won’t carry backwards (I don’t think it carries forwards anymore either – you have reload each picture, I think). Otherwise, you should be fine.
    Michael Hancock
    Editor
  • Job Ter burg
    June 1, 2012 at 3:21 pm
    I’ve gone back and forth quite a bit on two projects over the past months. No issues.
