Activity › Forums › Maxon Cinema 4D › Symmetry and Connect objects acting destructively with child polygons
  • Symmetry and Connect objects acting destructively with child polygons
    Posted by Xavier Bonet on January 12, 2022 at 2:52 pm
    In theory, until you make a Symmetry or Connect “group” editable or hit Current state to object, whatever “changes” you do to the Symmetry or Connect remain there and the inside or rather base polygons aren’t affected at all. However, recently I’ve encountered what surely must be a bug: whenever you play around with the Tolerance, and it deletes edges, it deletes these edges on the base object… Furthermore, this is not undoable, so unless you saved a previous instance with the untouched base polygons you’ve lost that topology. Something which clearly shouldn’t be happening, as that’s the whole point of using parent object to non-destructively affect their children. Has anyone else encountered this issue?
    Xavier Bonet replied 4 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
