Activity Forums Sony Cameras SxS PRO 32 Gb Not Recognised
  • SxS PRO 32 Gb Not Recognised
    Posted by Lawrence Gray on September 9, 2009 at 10:33 am
    I just bought a 32gb SxS Pro memory card for my EX1 and I’m given an Unknown Media message and no way of formatting the card.
    I check the web site and it says EX1 may need a software upgrade… I’m assuming that’s the problem. So how do I get one of these? I can’t find anything on the sony sites.
    Craig Seeman replied 17 years ago 5 Members · 11 Replies
  • 11 Replies
  • Rafael Amador
    September 9, 2009 at 10:50 am
    Try to format it in your computer. FAT 32.
    Rafael
    http://www.nagavideo.com
  • Lawrence Gray
    September 9, 2009 at 10:57 am
    Afraid I haven’t got any slots that fit that card. Is it the card or the camera that’s the problem?
    Lawrence Gray
  • Rafael Amador
    September 9, 2009 at 11:03 am
    Connect your camera via USB.
    Will show up like any other external device.
    rafael
  • Craig Seeman
    September 9, 2009 at 2:24 pm
    Unknown media in the camera?
    Camera should be at firmware 1.11 or higher to use 32GB cards.
    Press and hold MENU and CANCEL, SEL/SET to access the maintenance menu.
  • Noah Kadner
    September 9, 2009 at 2:26 pm
    Yeah that’s firmware. Needs to be updated…
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the 24p, HD and Final Cut Studio.
    Now featuring the Sony EX1 Guidebook, Panasonic HVX200, and Panasonic DVX100.
    https://www.callboxlive.com
  • Ronn Kilby
    September 9, 2009 at 2:51 pm
    You’ll need to upgrade the firmware. Depending on where you are, Sony will charge you between $0 and $200 to do it, and take between 2 days and 2 months to get it back to you. Or if you don’t mind risking turning it into a brick, you can do it yourself.
    There are places to download the update software, step-by-step instructions (https://www.vimeo.com/2686923), etc. Just google EX-1 firmware update.
    http://www.kilby.tv
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Lawrence Gray
    September 9, 2009 at 3:35 pm
    If I upgrade the firmware will I still be able to use m 8gb and 16gb cards?
    Lawrence Gray
  • Ronn Kilby
    September 9, 2009 at 3:40 pm
  • Craig Seeman
    September 9, 2009 at 3:54 pm
    And you’ll be able to use inexpensive SDHC cards.
  • Lawrence Gray
    September 9, 2009 at 4:36 pm
    Well that’s at least something… Wish I’d known this before forking out for the card. I’d have probably just bought myself a second hand camera!
    Upgrading it myself looks too scary. I’ll see if SOny, unlike Apple, here in Hong Kong know what I’m talking about when I phone them.
    Lawrence Gray
