Activity Forums Sony Cameras sxs crash
  • sxs crash
    Posted by Francis Youri on July 4, 2011 at 4:05 pm
    Hie,
    I did an update recently on june 30th suggested from apple and can’t read sxs cards anymore from my macbook pro. It crashes to a panic state. This was a java update and a security update, Any suggestions.
    Model Name: MacBook Pro
    Model Identifier: MacBookPro1,2
    Processor Name: Intel Core Duo
    Processor Speed: 2.16 GHz
    Number Of Processors: 1
    Total Number Of Cores: 2
    L2 Cache: 2 MB
    Memory: 2 GB
    Bus Speed: 667 MHz
    Boot ROM Version: MBP12.0061.B03
    System Version: Mac OS X 10.6.8 (10K540)
    Kernel Version: Darwin 10.8.0
    So many things to do, so little time
    Milivoj Ivkovic replied 14 years, 7 months ago 5 Members · 7 Replies
  • 7 Replies
  • Craig Seeman
    July 4, 2011 at 4:41 pm
    SXS in Express card slot?
    Update to current driver.
    https://pro.sony.com/bbsc/ssr/micro-xdcamexsite/resource.downloads.bbsccms-assets-micro-xdcamex-downloads-SxSDrivers.shtml
    Ignore the wording on the page. It should take you to the current SxS driver. You may need to use something other than Safari to download it as well.
  • Francis Youri
    July 4, 2011 at 11:36 pm
    Thanks Mr. Seeman, but it did not improve. Still crashing on inserting the sxs card in Express card slot. I had updated other soft from sony just in case but I was up to date on all. I uninstalled and reinstalled with the new ones but to no change. Is there a preference I should delete?
  • Francis Youri
    July 5, 2011 at 2:22 am
    Trying to prove my point, I took my son’s laptop about the same except he did not do the last apple update and all went well. So now I got my three days shooting on a couple of drives and I will try to have answers from apple. This was a java update and a security update.
  • Craig Seeman
    July 5, 2011 at 4:13 am
    How did you update to 10.6.8?
    Software Update can cause problems.
    Repair Disk Permissions
    Go to Apple’s site and download OS 10.6.8 Combo Updater.
    https://support.apple.com/kb/DL1399
    Install
    Repair Disk Permissions.
    Install Sony driver again.
  • David Wheeler
    July 7, 2011 at 3:49 am
    Hi Craig, I have the same issues with my MacBook Pro after upgrading to OS 10.6.8. I repaired disk permissions, downloaded the update combo and reinstalled the SXS drivers exactly as you suggested and the problem persists. As long as I boot up with the SXS installed in the express card reader, everything is fine, but when I hot-swap the SXS cards, the system crashes. A semi-transparent grey screen moves down the page and instructs me to do a hard reboot. Interestingly, it only happens with the SXS cards. No problem with an MxR adapter and SDHC card.
    Thanks for your normally spot-on suggestions, but this one didn’t work.
    Dave
    David Wheeler
    EX1; EX3; FCP 6.06; 17″ MBP, MacPro Quad
    CS4
    dave@marcombiz.com
  • Richard Van der vieren
    November 6, 2011 at 4:43 pm
    same problem here. would updating to lion be a solution?
  • Milivoj Ivkovic
    February 1, 2012 at 11:36 am
    According to Sony, the only solutions are to stay with 10.6.7 or to upgrade to Lion (but that may bring other problems).
    See also here: https://miblog.alma.ch/2012/02/sxs-cards-crash-os-x-1068.html
