Activity › Forums › DaVinci Resolve › Switching to Timeline mode is disabled
  • Switching to Timeline mode is disabled
    Posted by John Vogel on May 10, 2019 at 5:39 pm
    It says – Please disable “timeline filter” and “show clip with handles” to be able to switch to Timeline mode.
    I found the “show clip with handles” and it’s not enabled. “Timeline filter”?
    Can someone please explain? Not coming up in any search.
    jv
    Michael Gissing replied 7 years, 4 months ago 3 Members · 3 Replies
  • Ole Kristiansen
    May 10, 2019 at 6:17 pm
    Hi John
    Did you google: Davinci Resolve switching to timeline mode is disabled ?
    Best,
    Ole
  • John Vogel
    May 10, 2019 at 7:48 pm
    Thanks Ole!
    I forgot to mention I was in the color section, BUT your link led me to a solution because it’s all related. In Deliver, under the “File Edit Trim Timeline, etc” at the top there is “Clips”. There’s a long selection of choices and my sequence was under “Grouped” which I had grouped the entire sequence into 1 group to put a lut on everything. That selection needed to be on “All Clips”. Once I choose that, everything freed up in Color and Delivery.
    Thanks Ole!
    jv
  • Michael Gissing
    May 11, 2019 at 3:22 am
    The easy way to apply a grade to the whole timeline is to change from Clip to Timeline on the grade page. Grouping makes more sense to do to a smaller groups within the timeline, not the whole timeline. It works but the ability to add a grade to the whole timeline is already there.
