Activity Forums Apple Final Cut Pro Legacy Switching Tabs in FCP.
  • Switching Tabs in FCP.
    Posted by Steve Cohen on January 18, 2007 at 2:19 pm
    In a pod cast that Martin Baker did on Digital-Heaven, he said that in FCP 5.1.2 and later you can now switch between tabs using keyboard shortcut Shift Command Right or Left Square Bracket.
    I can’t seem to get this to work.
    First of all when you hit Shift it changes the Square bracket [ to Wavey Bracket {.
    Either way It doesn’t seem to work. Any Ideas.
    I was really excited to hear this was now an available feature, but upset when it didn’t work.
    Thanks;
    Steve Cohen
    Senoir Editor
    O2 Media Inc.
    Martin Baker replied 19 years, 6 months ago 4 Members · 5 Replies
  • Steven Gonzales
    January 18, 2007 at 3:28 pm
    “shift command(apple) [” or “shift command(apple) ]” works for me to change tabs on active window.
  • Martin Baker
    January 19, 2007 at 8:44 am
    Steve
    I had the same issue when I upgraded from v5.1.1 to v5.1.2, which might be the reason in your case too.
    If you haven’t remapped your keyboard layout:
    – Choose Tools > Keyboard Layout > Customize
    – Unlock the keyboard layout
    – Click the Reset button
    – The next/previous tab shortcuts should show up on the correct keys
    If you have remapped your keyboard layout:
    – Enter “tab” in the command search field
    – Drag “Select Previous Tab” and “Select Next Tab” to the desired key combinations
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! DH_RetroTV and DH_Dream plug-ins for FCP
    NEW! Hot Tips video podcast for FCP
  • Steve Cohen
    January 19, 2007 at 6:22 pm
    Martin;
    Thanks for the input.
    That did it. It works perfectly now.
    I had my keyboard modified, but the others in the company that weren’t modified didn’t work either so I rest those and they work fine now too.
    Thanks again.
    I know it’s trivial, but that may be my favorite feature.
    I just have to remember to use it now.
    Steve Cohen
    Senoir Editor
    O2 Media Inc.
  • Jaleeb Caru
    February 20, 2007 at 10:57 pm
    I’m still running 5.04, is this why this solution will not work for me?
  • Martin Baker
    February 20, 2007 at 11:24 pm
    Yes. It was new in 5.1.2
    Martin
    NEW! Final Print for FCP
