Activity › Forums › Apple Final Cut Pro Legacy › Switching of Effects in the Timeline
  • Switching of Effects in the Timeline
    Posted by Sascha Engel on June 10, 2009 at 8:17 am
    HI Everybody,
    following problem: I finished editing a video clip, in the Timeline, on each clip is also a number of effects (light, color corrections and so on). Now, I am making a different version of the clip – replacing some shots (li sync issue with the Spanish Market), and I want to switch all the effects in all the clips off, go into editing again, and then switching them on again. Is there any other way than going into each clip and unchecking the effect boxes one by one? Something like ‘select all’ => switch off all active effects.
    Did not seem to find that yet.
    Thanx a lot.
    Greetz,
    Sascha Engel
    Sascha Engel replied 17 years, 3 months ago 2 Members · 2 Replies
  • Massimo Croce
    June 10, 2009 at 8:58 am
    go to senquence setting>render control and uncheck filters under render & playback,
    this will disable all filter rendering on selected sequence.
    i notice that you need to close and reopen timeline
    remember to reactivate before final output
  • Sascha Engel
    June 10, 2009 at 12:54 pm
    Thanx a lot!!!! 🙂
