Switched from NTSC to PAL camera, now ‘Preview disabled’
Switched from Sony MiniDV NTSC cam, which worked perfectly, to Sony MiniDV PAL DCR-HC90E and am now unable to Log & Capture. Changed FC Pro 4.5 Easy Setup to DV PAL. Camera follows commands (play, stop, etc.) but preview is disabled. When trying to log I get the error message ‘The operation could not be completed as there is no video’. System profiler sees the camera. I cannot capture in iMovie either. Display is set to FireWire PAL and external video set to All Frames.
Was told that the problem has to do with camera/tape, rather than Mac/FCP.
This is urgent, need to deliver edited video by Thu (and stupidly told client doesn’t matter if NTSC or PAL…). Please help, thanks!
Alexander
