Activity › Forums › Adobe After Effects Expressions › switch() difficulty
  • switch() difficulty
    Posted by Jean Piche on September 9, 2021 at 5:24 pm
    Don’t quite know what is wrong. This expression simply doesn’t work. It aims to set a Tumble parameter depending on a series of choices that live in a Dropdown menu expression controller. The value of the dropdown does carry through, but the switch(xx) and case statements do not work at all. Here is the expression:
    xx = thisComp.layer(“OFFSET”).effect(“FLIP MODE”)(“Menu”);
    var jjj = 0
    switch(xx){
    case 1: jjj =0; break;
    case 2: jjj =10; break;
    case 3: jjj =30; break;
    case 4: jjj =50; break;
    case 5: jjj =90; break;
    case 6: jjj =130; break;
    case 7: jjj =180; break;}
    jjj;
    Any ideas? Many thanks!
    Fabrice Leconte replied 5 years ago 2 Members · 1 Reply
  • Fabrice Leconte
    September 9, 2021 at 6:04 pm
    Hello, line 1, convert the string to a number.
    xx = Number(thisComp.layer('OFFSET').effect('FLIP MODE')('Menu'));
    var jjj = 0
    switch(xx){
    jjj;
